Anybody used the Spartan-3 PCI Express Starter Kit?
staraimm
Full Member level 2
Full Member level 2
this core does not support asy symbol generation
I bought the developping board and downloaded the IOControl_81.zip from the xilinx website. The demo project was compiled by the ISE 8.1i, and I installed the ISE8.2i. When the software generated the logic core, errors happeded as follows:
Somebody met the same problem?
Started : "Launching Design Summary".
Customizing IP...
8.2i - Xilinx CORE Generator IP GUI Launcher I.31(c) 1995-2006 Xilinx, Inc. All rights reserved.Finished Customizing.
Generating IP...
WARNING:sim:99 - The Implementation File Type <Edif> is not valid for this core. Overriding with File Type <ngc>.
WARNING:sim:100 - The Simulation File Type <Behavioral> is not valid for this core. Overriding with File Type <structural>.
WARNING:sim:229 - This core does not support ASY symbol generation.
WARNING:coreutil - coreutil:8 - Feature <pcie_pipe_v1> is enabled with alicense.Generating Implementation files.
Generating the VHDL instantiation template.
Generating the Verilog instantiation template.
Generating the SYM file.
Generating ISE symbol file...
WARNING:coreutil - Failure to create .sym symbol file. Cannot post process asy symbol file. File pci_express_pipe_v1_3_2.asy does not exist.
WARNING:coreutil - This IP does not support SYM file generation.
Generating NGC file.
Generating VHDL structural model.
Generating Verilog structural model.
Finished Generating.
Successfully generated pci_express_pipe_v1_3_2.
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designEP_MEM.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designimpl_test.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designpci_exp_1_lane_epipe_ep.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designpci_exp_32b_app.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_32.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_32_RX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_32_TX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_64.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_64_RX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_64_TX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_EP.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_EP_MEM_ACCESS.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_TO_CTRL.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_1_lane_epipe_ep-XC3S1000-FG676-4.ucf listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_1_lane_epipe_ep-XC3S500E-CP132-5.ucf listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_pci_exp_1_lane_epipe_endpoint_product.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_pci_exp_1_lane_epipe_ep.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementimplement.bat listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementimplement.sh listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementxilinx_pci_exp_1_lane_epipe_ep_inc.xst listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementxst.scr listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationoard.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationoard_common.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionaloard_rtl_x01_epipe.f listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionalsimulate_mti.do listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionalsimulate_ncsim.sh listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionalsimulate_vcs.sh listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionalwave_mti.do listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionalwave_ncsim.sv listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulation unctionalxilinx_lib.f listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_cfg.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_com.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_rx.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_tx.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpx1011a.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpx1011a_pli.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationsys_clk_gen.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationsys_clk_gen_ds.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationxilinx_pci_exp_32bit_cor_ep.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationxilinx_pci_exp_defines.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
spartan 3 for pci express
Nobody met the same problem?
coregen xilinx pci express
The problem is resolved.
The ISE 8.2i can't allowed the ip core configure file .xco as one of the project files. If so, the top level file can't be compiled.
