staraimm
Full Member level 2
this core does not support asy symbol generation
I bought the developping board and downloaded the IOControl_81.zip from the xilinx website. The demo project was compiled by the ISE 8.1i, and I installed the ISE8.2i. When the software generated the logic core, errors happeded as follows:
Somebody met the same problem?
Started : "Launching Design Summary".
Customizing IP...
8.2i - Xilinx CORE Generator IP GUI Launcher I.31(c) 1995-2006 Xilinx, Inc. All rights reserved.Finished Customizing.
Generating IP...
WARNING:sim:99 - The Implementation File Type <Edif> is not valid for this core. Overriding with File Type <ngc>.
WARNING:sim:100 - The Simulation File Type <Behavioral> is not valid for this core. Overriding with File Type <structural>.
WARNING:sim:229 - This core does not support ASY symbol generation.
WARNING:coreutil - coreutil:8 - Feature <pcie_pipe_v1> is enabled with alicense.Generating Implementation files.
Generating the VHDL instantiation template.
Generating the Verilog instantiation template.
Generating the SYM file.
Generating ISE symbol file...
WARNING:coreutil - Failure to create .sym symbol file. Cannot post process asy symbol file. File pci_express_pipe_v1_3_2.asy does not exist.
WARNING:coreutil - This IP does not support SYM file generation.
Generating NGC file.
Generating VHDL structural model.
Generating Verilog structural model.
Finished Generating.
Successfully generated pci_express_pipe_v1_3_2.
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designEP_MEM.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designimpl_test.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designpci_exp_1_lane_epipe_ep.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designpci_exp_32b_app.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_32.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_32_RX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_32_TX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_64.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_64_RX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_64_TX_ENGINE.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_EP.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_EP_MEM_ACCESS.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designPIO_TO_CTRL.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_1_lane_epipe_ep-XC3S1000-FG676-4.ucf listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_1_lane_epipe_ep-XC3S500E-CP132-5.ucf listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_pci_exp_1_lane_epipe_endpoint_product.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2example_designxilinx_pci_exp_1_lane_epipe_ep.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementimplement.bat listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementimplement.sh listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementxilinx_pci_exp_1_lane_epipe_ep_inc.xst listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2implementxst.scr listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationoard.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationoard_common.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionaloard_rtl_x01_epipe.f listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionalsimulate_mti.do listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionalsimulate_ncsim.sh listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionalsimulate_vcs.sh listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionalwave_mti.do listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionalwave_ncsim.sv listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationunctionalxilinx_lib.f listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_cfg.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_com.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_rx.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpci_exp_32bit_usrapp_tx.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpx1011a.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationpx1011a_pli.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationsys_clk_gen.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationsys_clk_gen_ds.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationxilinx_pci_exp_32bit_cor_ep.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
ERROR: A coregen generated file pci_express_pipe_v1_3_2simulationxilinx_pci_exp_defines.v listed in the file pci_express_pipe_v1_3_2_flist.txt does not exist in the project directory!
Customizing IP...
Generating IP...
