Hk558
Newbie level 2
- Joined
- Dec 19, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 22
Hi guys
I am designing a very simple dipole antenna using HFSS. However I am not able to run the analysis.
Here is the problem; As you see, there is a port refinement problem. I have added integral line and everything is connected and there is no gap between port and my dipole antenna.
Please help me by your instructive suggestions.
$begin 'ProfileGroup'
StartInfo='Time: 12/19/13 15:19:31; Host: argon.ece.cornell.edu; Processor: 32; OS: Linux 2.6.32-431.el6.x86_64; HFSS 15.0.2'
TotalInfo='Time: 12/19/2013 15:19:34, Status: Engine Detected Error'
ProfileTask('', 0, 0, 0, 0, 0, 'Executing from /opt/local/ansoft/hfss15.0/Linux/HFSSCOMENGINE.exe', false, true)
ProfileTask('', 0, 0, 0, 0, 0, 'Desired RAM limit not set.', false, true)
ProfileTask('', 0, 0, 0, 0, 0, 'Solution Basis Order: 1', false, true)
ProfileTask('Mesh Refinement', 0, 0, 0, 0, 0, 'Lambda Based', false, true)
ProfileTask(' Mesh (lambda based)', 1, 0, 1, 0, 45656, '1496 tetrahedra', true, true)
ProfileTask('Mesh Refinement', 0, 0, 0, 0, 0, 'Port Adapt', false, true)
ProfileTask('Simulation Setup', 0, 0, 0, 0, 24984, 'Disk = 0 KBytes', true, true)
ProfileTask('', 0, 0, 0, 0, 0, '', false, true)
ProfileTask('Solution Process', 0, 0, 0, 0, 0, 'Elapsed time : 00:00:02 , Hfss ComEngine Memory : 233 M', false, true)
ProfileTask('', 0, 0, 0, 0, 0, '***Port 1 does not have a solved inside material on either side.', false, true)
$end 'ProfileGroup'
$end 'ProfileGroup'
