an old CTS question - sizes of clkcells for clock tree
devop
Full Member level 1
an old CTS question
Hi guys:
why we dont use the smallest and largest clkcell when building clock tree?
we usually us 3x 4x....16x clockbuf ,what about you?
thanks a lot
devop
Full Member level 1
Re: an old CTS question
devop said:
Hi guys:
thanks a lot
can anyone kindly share the experience??
do you use 1x or 64x clockbuf in you design?
devop
Full Member level 1
upup
one more question,would I use regular buffer instead of CLKBUF if the skew is not a big issue??
koggestone
Member level 4
My Intuitive guess is
smallest clkbufs - are more sensitive to Process variations , hence clock skew(OCV)
issues.
Largest clkbufs - have more Current , Hence Electromigration(EM) /Reliability
related issues , (besides too much of Power Consumption).
devop
Full Member level 1
issues.
I am confused here,
case 1, 10 smallest buf1X connet in series to drive a load
case 2, 1 biggest buf64X drive the same load
I think case 1 will be better in OCV? what's your opinion?
koggestone
Member level 4
devop said:
I am confused here,
case 2 has Less OCV .
Refer to famous Pelgrom's 1989 paper on Mismatch.
Bottom Line is - Variations are inversely proportional to Transistor Area (W.L).
Bigger Buffers (i.e Big W ) will decrease Variations.
Hence u see all those Microprocessor Global clk design guys and Anolog
designers will love to use bigger Transistors to decrease mismatch at the
expense of more power dissipation.
devop
Full Member level 1
koggestone said:
devop said:
I am confused here,
thanks koggestone
I consider the question in another way,
case 1, 10 cells , they scatter in a big area, the ocv for the whole path will be better,
just for a certain cell ,you are right ,Bigger Buffers (i.e Big W ) will decrease Variations.
