AMS .35 HV process Layout Issue
mvj
Dear All,
I am working on the layout of my circuit and I am having a problem which I am not able to resolve, can you please help me out.
When I run DRC I get the below mentioned error though the gate terminals are connected to a pin.
[1] ERCWarning: floating gate not connected to s/d, pad, pin or resistor.
To reproduce this problem, i have taken a trasistor and connected pins to all the terminals of the device. At the gate terminal, I connected a poly to M1 contact, then VIA1, M2 Track and M2 pin (images attached for you reference). I have checked it throughly but I am not to resolve this problem. Can you please help me out.
Thanks a lot in advance!!
Best Regards,
M.
hi mvj
if LVS is clean I would not bother with an ERC issue flagged by DRC, chances are that it is miscoded
... error though the gate terminals are connected to a pin.
At the gate terminal, I connected a poly to M1 contact, then VIA1, M2 Track and M2 pin ...
Did you also use the MET2 pin layer?
I don't know about Assura but for Calibre the port stamping layer is PIN:metal2 (abbreviated PIN:M2 in LSW) not MET2:pin; for example the latter is not exported to gds...
Your prb is an ERC and not a DRC probkem.
I got the problem resolved.
I placed a pin ( ctrl + p). This is ok for DIVA and not for Assura. In Assura a layer of type PIN:M2 should be placed as mentioned by dgnani.
Thank you for your help!!
