About Lacthup remedies
nagamlan
Junior Member level 3
How guard rings actually reduces lacthup???? Thanks in advance....
A guard ring is a ring (or very nearly so) surrounding a sensitive part of a circuit and connected to earth or a low impedance voltage which is at the same potential as the sensitive bit. It is so leakage currents through the air or across the printed circuit board flow into the guard ring and not into the sensitive circuit. Only really used with voltages in excess of 500V or impedances greater then 100 M ohm.
Now, how they effect latch up is a mystery, though its good to keep leakage paths under control. There are many sort of latch ups, I suppose you mean semiconductor devices when driven with too many volts, suffer an avalanche breakdown, which if the current is limited is non-catastrophic, i.e. when the voltage is removed the device recovers. Hence the requirement to control your high voltage leakage paths with guard rings.
Frank
Hi Frank its Amlan. Thank u 4 ur kind suggestions. But I am looking 4 the case, where in a CMOS substrate some current flows though the body due to the formation of 2 virtual BJTs.
Correct guard ring will reduce the base resistance of 2 parasite BJTs. If the current gain in the loop will be less than 1, there will be no latch-up.
yes dat's r8...but how it reduces base resistance actually???
Latch up will prevent the lateral entry of minority carriers by forming a reverse biased pn jun.
Guard ring provides lower resistance because its doping is heavier than well resistance without guard ring.
And more contacts in guard ring also reduce contact resistance.
