about Create symbol in WG2004
sonicss
Member level 1
Member level 1
China
I want to create a symbol which has some pin with the same name. But I can't do it in Library manager for dc. how can I do it.
tux
Member level 4
Member level 4
Hi
Each Pin should have a different name.
for example:
u have 5 vcc pins
name it as
vcc_1
vcc_2
vcc_3
vcc_4
vcc_5
if u name it in sequence . it will be useful for cross checking the pin count also.
    sonicss
sonicss
Member level 1
Member level 1
China
Thank u. I think it's very terrible. :cry:
xvibe
Member level 5
Member level 5
Portugal
Another way is ommiting the VCC and GND pins in the symbol and add them in Library Manager -> Parts Database -> (select your device) Pin Mapping -> Supply and NC. Then you attribute the name and pin number for your pin.
In the schematic you got to the properties of the symbol and add a supply rename like this VCC=3V.
    sonicss
Uky
Member level 5
Member level 5
Swedish West Coast
There is a way to make several pins have ie. name "GND". Name the pins "GND_1, GND_2 etc. Then modify the text properties to "Hidden" and then add manual text "GND" to the pins. That way, you can name them anything you want. But IMHO it may make a netlist review more difficult. Assigning other names like xvibe suggests is also possible, but this will also make netlist review difficult. Mixing supply voltages in a complex design is easier when all pins have "real" names and supply voltages can be clearly seen in the schematics. Quite a few supportnet tickets I have seen deals with netlist problems that comes from net assignments that does not match when doing CDB.
    sonicss
