E=MC2
Newbie level 6
mains outlet
i have a question about the ground (earth) of the mains outlet.
i have read somewhere that the neutral and the ground wires are usually connected together at the local power transformer. so there shouldnt be any voltage between the ground wire and the neutral wire. but ive seen in a number of places that there is a voltage of about 5-8 Volts between the neutral and the ground. ive also read that this is due to load imbalances and this is quite normal in a typical residential setting. but is this okay for a computer????
what is the solution to this? is it okay to make a separate ground by yourself? and for instance if i bury a wire in a flower pot close to my computer and connect it to the ground of the outlet which the computer is using, would it be dangerous?
