A question about Cadence Virtuoso
tral
Newbie level 3
I'm a freshman of IC. When using Virtuoso to extract the parasitic parameters of layout, I was told the software could extract just the parasitic RCs of a single wire or several selected wires instead of the whole layout. However, I don't know how to do this.
Needing your help:)
Hi tral
I used Virtuoso several years ago,so I could only give you some rough hints :roll:
Virtuoso uses LPE to extract the parasitic parameters of layout, so you must have a script file similiar to DRC/LVS check command script file and you can specifiy the nets you want to extract parasitic RC parameters.
For further details,pls refer to Virtuoso manual. :wink:
Maybe it's really troublesome for Virtuoso or Diva. But now I think I can solve the problem by Mentor Calibre.
Thank you anyway!
In the submicrometer(<0.35um), the synopsys Apollo is the better the3n cadence, u may try and compare.
I use dracula to do LPE for whole layout above 0.25um, and use hercules to do it below 0.25um.
but firstly, you should get the deck.
u can use calibre to extract RC, it is a very fast and friendly tool
Go to menu bar in virtuoso Verify------>Extract------> from the extractor form there is option Switch Name you can set R/C or RC parasitics
I think u must to write a diva rule by yourself to extract one net RC.
Your statement is wrong and not relevant to the question
use calibre PXE for extracting the RC
PXE is parasitic extraction
