75 ohm to 50 ohm conveter?
7rots51
75 50 ohm transformer vhf
please give a circuit for 75 ohm to 50 ohm conveter?(f=400~500MHZ)
is there any simple and accurate way?
Borber
Advanced Member level 5
on third flor
Circuit depends on allowed attenuation. It can be pure resistive Γ cell or transformer with 1:1.22 ratio .
melc
Full Member level 6
It could be also a simple layout on PCB and if distance is small it might even don't care at this frequency (assuming the signal source and signal load are not sensitive to impedance variations).
7rots51
please give a circuit with resistor ,LC
palesha
Full Member level 2
My suggestion is to use transformer type. As ur frequency is just 400~500 Mhz.
If u r ready to waste so much power just to match, then resistive is ok.
All VHF /UHF 300 ohm to 75 ohm convertors r of transformer type.
masadi
Member level 4
Could you give a picture of example 75-50 ohm coverter of transformer type?
if the frequency is higher than VHF/UHF, what kind of 75 to 50 ohm converter will be better to use?
thx
7rots51
if we connect 75 ohm source(or system) to 50 ohm load(or system) what is the loss in dbm in RF power? what is VSWR?
BigBoss
Turkey
For a single frequency a LC pair will perform this matching but over a wideband, "Wideband Ferrite Core Transformers" must be used to convert 75-50 impedance scaling..
Resistive dividers are very lossy..
palesha
Full Member level 2
for wideband tranformer matching info refer to
Radio Frequency Transistors
Principles and Practical Applications
Norman Dye
Helge Granberg
Ch. 10 Wideband Impedance Matching
There is a special detailed chapter.
Hope this helps,
Borber
on third flor
h**p://rapidshare.de/files/21321305/DYE__N.__2000_._Radio_Frequency_Transistors_-_Principles_and_Practical_Applications__2nd_ed._.rar.html
Borber
on third flor
R1 and R2 are calculated from Eq1 and Eq2. RL and RS are known.
