[AVR] 74HCT541 to translate 5V logic to 3.3V logic
sreepss
Full Member level 4
Cochin, Kerala, India
Shall we use 74HCT541 to translate from a 5V logic to 3.3 logic? I mean from a 5V processor lines to a 3.3V display lines?
I have tried this, but a 3.3V powered HCT 541 gives wrong output (4.1 V) and disturbing the 3.3V supply rail. :roll:
here's my schematic
andre_teprom
Super Moderator
Staff member
Brazil
You are simulating with the 74HCT541 ( 4.5v-5.5v ), but should use the 74HC541 ( 2.0v-5.5v ) instead. Anyway, according to datasheet the maximum allowed input is VCC.
KlausST
Super Moderator
Staff member
What's the idea behind using a HCT device? I can't see it.
Use a AHC device, but supplied with 3.3V.
Then the output is 0V/3.3V....while the input may be higher than it's supply voltage.
Klaus
sreepss
Full Member level 4
thanks for the replays,
Negative Negative
I have actually used HC541 not HCT. Sorry for the mistake whenever I give the input to the buffer from a 5V ATMEGA port, the output goes beyond (4.1V the HCT's VCC( 3.3V ) and the 3.3V power rail raised by 4.1V.hc5411.jpg
KlausST
Super Moderator
Staff member
May I ask why you don't use 3.3V supply for the Atmega?
Klaus
sreepss
Full Member level 4
hi KlaussT,
I have already running design of ATMEGA with 16MHz clock. I need to run it with 8MHz for 3.3V design. currently I cannot change the design
KlausST
Super Moderator
Staff member
Again: use AHC, supplied with 3V3.
HC are not 5V input tolerant with 3V3 supply.
Klaus
KlausST
Super Moderator
Staff member
Any AHC family member has this 5V tolerant inputs.
If you need 541 functionality... then
Yes, use 74AHC541.
Klaus
Reactions: sreepss
    sreepss
