I'm having trouble finding data regarding SRAM read/write currents for 7nm nodes.
Most of the results/data I've seen seem to be done on larger technology nodes, or on the noise margins.
Currently, at most I've found that read/write currents are around 40~60 uA for Vdd=1V, but I think they might be too large?
Does anyone have data off the top of their heads, or could point me to some conference/journal/roadmap where I can find the data?
very few people have access to 7nm, and even fewer would be in a position where they can share these values. I can tell it certainly doesn't operate at 1V, nominal voltage is <0.8V.
Peak write current will be found at the "tipping point"
of the core cross-coupled inverters. You could mock
this up with min W, min L devices (although SRAM
leaf cells are often allowed to "cheat" specific rules
in the name of density, and you might not get to know
(say) that the min W is less than LGRP min W unless
you have gotten the PDK and library info from the real
foundry).
You might find "write charge" more useful than a write
current, peak or averaged. Flipping over a bit (write) or
reading a bit both act like a charge-slug per event,
gross supply current is leakage plus these "events"
and largely frequency dependent (as most CMOS).
Of course in SRAM detailed design the worst case write
current (peak) is what the write network has to source
or sink, through the access switches, and read current
obtainable without read turning into false write, drives
the sense line loading, precharge and sense amp design.
Whether this is about specification / characterization,
or about design, is not told.
