Junus2012
Advanced Member level 5
Hello
if we have a large capacitor load in term of some PF, then we need to use output stage for the basic OTA to be able to drive it with enough current for the slew rate without disturbing the biasing current of the core amplifier.
Perhaps you read the above sentences in different literature, but whenever I use the driving or the output stage I need to use a compensation capacitor C.C then again the slew rate is limited by the C.C and again we need to supply it with enough current especially if the CL is large then C.C will be also large, my question is '' what the driving circuit did for us in case of driving large CL with high S.R "
Thank you all
Thank you all
