Roel
Member level 2
heatsink in orcad
does anybody know how to make a Orcad component footprint with, for example, two pins with number 1, two pins with number 2,......
I need this for a RAM chip with two different package sizes. The pitch of the pins is the same but the width of the body differs and we are never sure which is available by our supplier. I would like to use a footprint wich makes it possible to use the two packages.
Another application for the 2-pin-and-one-number problem is to connect the heatsink of a switched mode power supply IC to the ground line using two pads with the same number.
Making extra pins in the schematic design and connect them to the corrsponding pins is no option. The schematic must give a clean overview of the board.
Roel
Roel
