16f84a or 16f628 timer
fuq
Newbie level 3
Hello Everybody!
i want build a 16f84a or 16f628a timer
i want switch on an heater 5min and turn off 2hours.
but i don't know where start . :cry:
Please, Please help me
thanks
You do not say if you know anything about what programming language or hardware you want to use, other than the pic chip.
You can Google for ready made timer projects or if you want to properly understand Pics then have a looks at this good practical Assembler tutorial using the 16F628A
http://www.winpicprog.co.uk/pic_tutorial.htm
    fuq
i am 0 :| in programming.
thanks for the beautyfull web can u give me another similar web? :D
Here is the code (in mikroBASIC) using PIC16F84A:
program timer84EDA
symbol heater = PORTB.B0
const fivemin = 300000
const twohour = 7200000
main:
     TRISB = 0
     PORTB = 0
     heater = 0 'heater off
     delay_ms(fivemin) 'five minute delay
     heater = 1 'heater on
     delay_ms(twohour) 'two hour delay
     while true 'done
     wend
end.
Circuit:
    fuq
hi Tahmid
thans for circuit and hex.:D
Dear Tahmid,
I tried your codes in "rnikroElektronika Basic compiler for Microchip PIC microcontrollers Version: 7.0.0.2"
The codes are :
program timer84EDA
main:
TRISB = 0
PORTB = 0
while true 'done
wend
end.
But I get following error messages while building.
11:12 E-3 Identifier 'b0' was not declared timer84EDA.pbas
17:6 E-3 Identifier 'wend' was not declared timer84EDA.pbas
19:1 E-4 Syntax error: Expected '.' but '' found timer84EDA.pbas
Please Help
Subbudu
program timer84EDA
main:
     TRISB = 0
     PORTB = 0
     while true 'done
     wend
end.
Dear Tahmid,
I tried your codes with some modification .
program 84Atimer
symbol ac1 = PORTB.B0
       ac2 = PORTB.B1
      led1 = PORTB.B2
      led2 = PORTB.B3
const onesec  = 60000
const threemin = 180000
sub procedure led1()
    led_Play(60000, 180000)                ' Frequency = 1Hz, duration = 3sec
end sub
sub procedure led2()
end sub
main:
     TRISB = 0
     PORTB = 0
     ac1 = 0 'ac1 off
     delay_ms(twohour) 'five minute delay
     ac1 = 1 'ac1 on
     ac1 = 0 'ac1 off
     while true 'done
     wend
     ac2 = 0 'ac1 off
     ac2 = 1 'ac1 on
     ac2 = 0 'ac1 off
     while true 'done
     wend
end.
but found error
error: 12 303 Identifier "led_Play" was not declared ac finale.mbas
error: 12 304 Syntax error: Expected "end" but "led_Play" found ac finale.mbas
error: 12 304 Syntax error: Expected "sub" but "(" found ac finale.mbas
error: 12 304 Syntax error: Expected "end" but "60000" found ac finale.mbas
error: 12 304 Syntax error: Expected "." but "," found ac finale.mbas
error: 0 102 Finished (with errors): 10 Jul 2011, 03:05:10 ac finale.mbppi
pl guide me , where i wrong ?
i hope u do it ...
Dear Tahmid,
The codes are :
program timer84EDA
main:
TRISB = 0
PORTB = 0
while true 'done
wend
end.
Please Help
Subbudu
I know it's a year late, but maybe someone else will find it useful. I think I used mikroBASIC PRO for PIC.
In v7.0.0.2, write
Code ASM - [expand]
symbol heater = PORTB.0
---------- Post added at 13:25 ---------- Previous post was at 13:23 ----------
Dear Tahmid,
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
program 84Atimer
       ac2 = PORTB.B1
      led1 = PORTB.B2
      led2 = PORTB.B3
end sub
end sub
main:
     TRISB = 0
     PORTB = 0
     ac1 = 0 'ac1 off
     ac1 = 1 'ac1 on
     ac1 = 0 'ac1 off
     while true 'done
     wend
     ac2 = 0 'ac1 off
     ac2 = 1 'ac1 on
     ac2 = 0 'ac1 off
     while true 'done
     wend
end.
but found error
i hope u do it ...
You called a function called led_play() but there is no function led_play() in your code. That's the error.
Hope this helps.
Tahmid.
my original requirement is ..
when power on
LED1_Blinking ,Frequency = 1Hz, duration = 3min
then
AC1_On ,2Hr
then
LED2_Blinking ,Frequency = 1Hz, duration = 3min
then
AC2_On ,2Hr
forever
