Switching 108 amps at say 20kHz, is not for the first timer, don't forget the 1st filter inductor must carry this current also - and attenuate the switching harmonics of the square edges - and the first filter cap must carry appreciable AC current too, in performing the filtering, then the 14V pri will carry only the load current ( and the magnetising current ) a modest cap on the HV output side ( 230Vac) of the Tx, say 2u2, 630VDC, can then provide the final filtering, using the small amount of leakage in the Tx.
Again - if you have not done this before - it will be a significant challenge.
