piyush1991
Newbie level 3
Hi
I have Design Op-Amp working with 1.2V Supply Voltage.
Then i have connected power transistor and feedback resistors, But as soon as i connect output of feed back resistors to the input of Op-amp all biasing voltages get changes and op amp output decreases to around 200mV and power transistors start operating in linear region and Vds=1.2mV across Power Transistor .I have used feedback resistors value around 5M-10M.
I thought it was due to loading effect So, i use voltage buffer in between Op Amp output and Power transistor input but still same thing happens
Can any one suggest me what should i do?
