[SOLVED] Calibre PEX error during generating calibre view
vieha007Electronic
Junior Member level 3
South Korea
Dear all,
I am facing one problem during Calibre PEX. The error appear as: "Calibre View generation encountered a fatal Error. Please consult the logfile for messages."
When I check the log file, it shows the content (as below). Do you have any idea or you met same issues?
Tks for your help in advance!
INFO: cds.lib has been converted to lib.defs /home/tools/Mentor/Calibre/calibre_2015.4_16.11/aoi_cal_2015.4_16.11/tmp/22230_result_lib.defs
RUNNING PEX back-annotation...
// Calibre FDI v2015.4_16.11 Mon Nov 2 13:46:00 PST 2015
// Copyright Mentor Graphics Corporation 2008-2015
// All Rights Reserved.
// THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
// WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
// OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
// Mentor Graphics software executing under x86-64 Linux
// 64 bit virtual addressing enabled
// This software is in pre-production form and is considered to be
// beta code that is subject to the terms of the current Mentor
// Graphics End-User License Agreement or your signed agreement
// with Mentor Graphics that contains beta terms, whichever applies.
// Running on Linux ncdl602 2.6.32-696.1.1.el6.x86_64 #1 SMP Tue Apr 11 17:13:24 UTC 2017 x86_64
INFO: Parsing command line arguments...
INFO: License checked out successfully for calibreqdb.
INFO: Parsing cellmap file...
INFO: Executing back annotation...
ERROR: Could not access LibDef plug-in for oaLibDefSystem: #4: Shared Library Not Found: Error loading library 'libddbase_sh.so'. /home/tools/Cadence/IC617/tools/lib/64bit/libddbase_sh.so: undefined symbol: _ZN8oaCommon11FactoryBase11getRefCountEv
The error message is quite clear and self-explanatory - a shared library is missing.
Why is it missing?
I have no idea about that.
You can talk to your CAD team, or contact Cadence or Mentor customer support to resolve this.
Why is it missing?
Thank you. I check that libddbase_sh.so is not missed. I am supported by a local-designated supports center so I could not resolve this using Mentor customer support. I am still looking for a solution.
BRs,
Dear,
I have fixed the issue. The problem is due to the lack of variable in the LD_LIBRARY_PATH setup.
"setenv LD_LIBRARY_PATH /usr/lib:/usr/local/lib:/usr/openwin/lib:$CDSHOME/tools/dfII/lib:$CDSHOME/tools/lib:$CDSHOME/tools/lib64:$MMSIMHOME/tools/ultrasim/lib:/home/tools/Cadence/IC615/tools.lnx86/lib/:/home/tools/Cadence/IC615/tools.lnx86/lib/64bit/"
As you can see, I added "/home/tools/Cadence/IC615/tools.lnx86/lib/:/home/tools/Cadence/IC615/tools.lnx86/lib/64bit/" in the LD_LIBRARY_PATH above (that is the link to the shared library that need to be used for PEX)
Hope it help!
    V
Hello
I have fixed this probelm in install ic617。 Until now ,I can not solve this issue, and is still puzzling me.
this pitcure is my report in terminal
