i give up simulating this circuit (flyback converter cicuit)
high voltage
Junior Member level 1
hii all
i did every think to get my desired output (12V) but i couldn't i hv tried changed MOSFET and rectifier diode many times but i still didnt get my output...where is the wrong here???
Lp37.5u
Ls75u
Vin12V
Vout24V
F200kHz
Check some of your component values to make sure that you are indeed using the correct values.
For example, you have C3=0.01F, most spice simulators will interpret this is 0.01 femto, where fempo is \[10^{-15}\], so in your case you might have a capacitor that is \[10^{-17}\] Farads. Also your inductor value for L7=1pH, this is \[10^{-12}\] Henries. Double check these values.
v_c
hii all
Lp37.5u
Ls75u
Vin12V
Vout24V
F200kHz
hello,
Plz try to simulate this circuit don't lose heart and make endeavours.i hope it'll help you.Regards
  • 12V+555.rar
I don't see a polarity marking at the transformer. The waveform suggests forward instead of the intended flyback operation. But you'll see when monitoring the secondary voltage.
what's the simulation software you are using ?
thnxx alll guys i really appreciate
thnx ch wazir ya it helped, seeing my desired output for the first is sumthin great..lol..thanx aloot man.. but actually i still ddnt got my waveforms...dont know why??!!!
iam using multisim dear vamsi57
plz find my attached circuit..
  • altayeb.rar
