bio_man
Full Member level 2
Hi All,
I remember that if I'm targeting CMOS Fabrication, rule of thumbs, bulk connection of pMOS must be connected to +VDD and bulk connection of nMOS must be connected to GND/-VSS. Is this true in all time? or as a designer you have the option to connect the bulk to higher/lower potential but not necessarily the extreme voltages in the circuit.
this came in mind, because I have a circuit with couple of floating transistors, i.e drain/source are not tied to the VDD/GND. so I was thinking if I can connect the bulk to drain/source to make Vsb=0 and avoid the body effect. I am not sure if this permissible in CMOS fabrication? BTW, if for for example bulk is connected to source in M1 and I am aware of the fact that Drain of this source should be higher the Vb or Vs to prevent forward biasing the pn junction between bulk and drain, and the opposite when connect bulk to drain.
