Thanks .what is the o/p wave form?Can this power lcd tv.Cos I design using sg3524 it cannot power lcd tv(samsung) but it power other load in my room both lg tv flatron
Waveform is something like this: http://www.oynot.com/images/modified-sine-wave.jpg
If it didn't powered the LCD TV, then there could be some possible reasons- output power is not sufficient for the tv, the tv circuit may be rejecting modified sine wave, or anything else.
I done thank that power is problem.I can more of the tv.In the design I use 10 pcs. of IRF150N .Push pull mode.I use sg3524.Waveform may the problem because when i connect .01uf at the inverter output the tv will try on and off .Thanks
If o/p of oscilator(sg3524/3525) is connected to negative feedback of Opamp(lm324)and 0.1uf(104) is connected to o/p and to negative.Can this alter the waveform of inverter?Thanks
