wondering about MOSFET ( second order effect)
vesperon
i'm pool at english, just listen TT
second order effect, in mosfet, punch through,
how can flow the 'current' through depletion region??
is that region cannot flow the current, right?
i cant understand why the current flow on punch-through.
avalanche breakdown?
Sure current can flow in a depletion region whenever charge carriers are available. A depletion region is only depleted (of charge carriers) if there is no source for new charge carriers. The leakage current through a depletion region consists of charge carriers diffusing into it or being thermally generated in it. Punch-through is given when a depletion region extends to a highly doped region which can inject charge carriers into it. See this excerpt from The Power Electronics Handbook: View attachment punch-through__The_power_electronics_handbook_p66-68.pdf
This is a different phenomenon. See the PDF above, too.
Leakage at the blocking junction is the "seed" for impact
ionization (avalanche at its extreme).
Once you accept that your textbooks are full of assume-away
and for-purposes-of-analytical-simplicity there's a whole world
of nonideal mechanisms to discover.
