mayang
Newbie level 6
Hi in the LTM4644 (https://www.analog.com/media/en/technical-documentation/data-sheets/LTM4644-4644-1.pdf), page 7 its says that " COMP is Current Control Threshold and Error Amplifier Compensation Point of Each Switching Mode Regulator Channel. The internal current comparator threshold is proportional to this voltage. Tie the COMP pins togetherfor parallel operation. The device is internally compensated." But not stated if I can float or mark as unconnected if not in use.
Should I leave it float or should I mark as Unconnected?
Thank you.
Thank you.
