rrucha
Member level 3
I wish to make a parameterized CRC generator that takes different widths of data in and gives 2 different types of CRC at the output. This depends on the parameter "crc_poly" which will decide whether the output CRC will be 32 bit or 64 bit.
My code will have all the different combinations of the CRC generators as a function.
Based on the select signal, I will pick which CRC to choose for my output. This is pretty straight forward.
I need help in understanding how I can have one parameterized module that can have two different output crc widths. I will attach a picture to explain better.
My question is, will i need two completely different CRC modules if the output width is not fixed? I know its possible to use the same module if only the polynomial differs but the widths stay the same. But in my case my output width is changing.
