concatenation in VHDL?
How to use concatenation operator in VHDL for shifting without using any function?
I think that’s three separate questions. You can use both concatenate or shift without a function.
Here’s one way to shift an 8-bit vector
result <= vect(5 downto 0) & “00”;  — shift left 2 bits.
You can only use the concatenation operator at the RHS of your assignment operator.
--- Updated ---
If you're having an issue with your code, then you may have to post the affected part of your code here.
LaTeX Commands Quick-Menu:
