Mukesh10
Junior Member level 2
Hello Everyone
Can anyone tell me wat is the meaning of this warning and help me in removing this warning :
Thanks And Regards
Mukesh Goyal
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(63): [CNNODP] - Component name (miso) is not on a downward path.
# Region: /soc_top/DUT/IP_TOP
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(53): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(44): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(35): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(65): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(54): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(45): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(36): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(67): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(55): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(46): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(37): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(69): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(56): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(47): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(38): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(71): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(57): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(48): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(39): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(73): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(58): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(49): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(40): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(75): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(59): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(50): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(41): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(77): [CNNODP] - Component name (miso) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(60): [CNNODP] - Component name (mosi) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(51): [CNNODP] - Component name (sclk_pad_o) is not on a downward path.
# ** Warning: (vsim-3008) ../rtl/ip_top.sv(42): [CNNODP] - Component name (ss_pad_o) is not on a downward path.
Thanks And Regards
Mukesh Goyal
