Gate level simulation issue on questasim
Farah Adel
Newbie
I want to simulate the net list on questasim. The design has ROMs. I want the simulator to see the db format of the memories because when i compile the gates of the technology and simulate the test bench with the net list, it produces an error that the memories are not defined. The following are 2 screenshots one after compiling the gates of the technology and when with the error appearing.
most likely the memory provider has given you a simulation model of the memory. you have to use it together with your tb.
And to complete "ThisIsNotSam", this model can be populated by your ROM C code compile and modify in the correct format.
