Query in expedition schematic tool (design capture):
Siva_vijiy
Newbie level 5
design capture bus naming
How to use the bus connection.
When I run the package for the design which had buses to interconnecting the set of nets. It show the error like “Wire ripped from bus is not a valid bus member” for each net.
Please help me to resolve this problem.
esrope designer
hi,
try any one of these option
1. In central library connector symbols check whether ESROPE symbol is there
2.give same bus name
i think first option will help to correct your problem
expedition +schematic
Thanks for the reply... I will try it and let you know the things.
Added after 48 minutes:
Do you have any .sbk file(schematic file) used with the buses? If so, please upload me. I need it for reference.
expedition bus design
Hi shabharudin,
Finally I resolved the problem. Thanks for the support...
Re: expedition bus design
Hi Siva,
I am also getting the same Problem , what is the procedure to fix this one...
Regards
Karthik
