Need help to identify this dev board
aaa3a
Newbie
hi dear friends
i need help to identfy this dev board this is it's photo attached
as i can see it has a built in programmer or something correct me if i'm wrong
i don't know how to program the microcontroller or which microcontroller it support
i have PIC16F877A-IP microcontroller
what i need is
1- to know what microcontroller it support
2- how to program the microcontroller
3- is there code examples for it
as i'm new in microcontroller
thanks
i expect that somewhere on the board, top or bottom,
there is a part number or a URL that will lead you to answers
hello
it is pic programmer via RS232c port beyond to microchip the 16f628a and max232c are for ICSP(in circuit serial program ) you need the software for instillation in you PC windows XP (includes com port hardware )
i managed to program pic16f877a with k150 programmer and it works but i want to use the built in serial programmer on board but i don't know where is the software that work with the serial port
hello
See(look for) the model on your dev board and type then search in google .at least you maybe find the manual in pdf file . is your dev board includes this I.C max232 .because the picture didn't show the side of RS232 com port ?
kamal
I thought I was good at finding documentation online for obscure PIC development boards but after three days of looking all I could find is a vague connection to Maamoon Electronics in Egypt.
More information about how you came into posession of this board could help.
I did finally find this link: http://www.voti.nl/wisp628/index.html
This is a PIC16F628A based In-Circuit-Serial-Programmer for PIC controllers. It is obsolete but the PC application that is used with it may be what you need. But it is impossible to tell from what you have posted.
