[SOLVED] AT89S52 receive is not working - 8051 RI interrupt Need urgent help
mprabu20
Newbie
Hi experts,
I am using AT89S52 microcontroller to implement a generic relay board. I am using RS232 to communicate.
when we sent data from laptop, RI interrupt is not being raised, and receive is not working. If I try only transmit its working fine. When I simulate on keil its working. But it fails on proteus simulation and on hardware. Please some one help.
Here is my code.
#include <reg51.h>
/* ---------------------------->This code is commented and working only transmission.
void main () {
    SCON = 0x50;
    TMOD = 0x20;
    TH1 = 0xFD;
    TR1 = 1;
    SBUF = 'Y';
    while (TI == 0);
    TI = 0;
}----------------------------------Till this commented
volatile bit rx_flag = 0;
volatile char rdata = 'K';
void init_serial();
    void main() {
     init_serial();
    while ( 1 ) {
    //RI = 1;
        if (rx_flag == 1) {
            SBUF = rdata;
            while (TI == 0);
          //rdata++;
            TI = 0;
      rx_flag = 0;
void init_serial() {
    SCON = 0x50;
    TMOD = 0x20;
    TH1 = 0xFD;
    TR1 = 1;
    ES = 1;       // Enable serial port interrupt
  EA = 1;       // Enable global interrupts
    //P3 = 0x03;
void serial_isr() interrupt 4 {
    if (RI) {
        rdata = SBUF;
        RI = 0;                // Clear the receive interrupt flag
        rdata++;/// = '7';
              rx_flag = 1;           // Set the flag to indicate that data has been received
HI,
what is "RI" interrupt?
"Ring indicator" signal form RS232?
In most cases this signal is not used at all.
Show your schematic.
You say "laptop". Does it provide a full featured RS232 interface?
I see you treat it as "Receive Interrupt".
We don´t see how you test it.
How can you be surre main() is running at all?
How can you be sure it does not hang on the "while (TI == 0) " line?
If you use port outputs for debugging you may easily see with a scope what happens.
Are you sure the RI and interrupt is correctly used?
You don´t provide a link to the datasheet, so we can´t validate.
There should be plenty of correctly working code examples in the internet. I assume the chip manufacturer provide some, as well as Keil.
Also: application notes and videos..
Klaus
Problem might be that neither TI isn't handled in serial interrupt routine nor interrupt is disabled during transmit. Processor can be caught in an endless interrupt.
However, as you say code is failing in Proteus as well, why not using debugger to see how and why it's failing?
