I've done a bit of work with manchester (biphase) coding.
It all depends on the datarate, and what exactly this 'manchester data' is. The 628 as far as I know can only manage 5MIPS. Also, is this a packet structure, or a continuous stream? If continuous, you'll have to do any processing between bits (manchester bits, not a data bit) which would reduce the datarate you can handle. Although, if you plan to 'over sample' the incoming stream, you could still read about 110kb/s.
If its bursty (packets) then you could just read in, decode 'on-the-fly' ie: if you receive a one, then a 0, then thats a '0' data bit, and a 0-1 is a 1. Sometimes its the other way around. A simple loop that periodically reads in, decodes, and stores. Then, between packets you can do what you want with the data.
Anything below about 500Kb/s I think can be done. I've done it.
But I assume you mean at a sensible datarate (<40kbs). In which case there are many options.
