Problem to read the http get response with GSM A7670
Naznee
Newbie level 6
this is my code
C:
#include <HardwareSerial.h>
#if defined(CONFIG_IDF_TARGET_ESP32)
    #define mySerial Serial2
#elif defined(CONFIG_IDF_TARGET_ESP32S2)
    #define mySerial Serial1
#elif defined(CONFIG_IDF_TARGET_ESP32S3)
#endif
String msg="";
void setup()
  Serial.begin(115200);
  delay(500);
    mySerial.begin(115200);
   mySerial.begin(115200, SERIAL_8N1, 18, 17);
 #endif
 mySerial.println("AT+CICCID");delay(500);
  update_serial();
  mySerial.println("AT+CREG?");delay(500);
  update_serial();
  mySerial.println("AT+CGATT=1");delay(500);
  update_serial();
  mySerial.println("AT+CGACT?");delay(500);
  update_serial();
  mySerial.println("AT+CGDCONT=1,\"IP\",\"jionet\"");delay(500);
  update_serial();
 mySerial.println("AT+HTTPINIT\r\n");delay(500);
  update_serial();
 mySerial.println("AT+HTTPPARA=\"URL\",\"http://api.timezonedb.com/v2.1/get-time-zone?key=KXXXXXXXXX&format=json&by=zone&zone=Asia/Kolkata\"");
delay(500);
  update_serial();
   mySerial.println("AT+HTTPACTION=0\r\n");delay(2000);
  update_serial();
  mySerial.println("AT+HTTPREAD?");delay(2000);
  update_serial();
  mySerial.println("AT+HTTPTERM\r\n");delay(2000);
  update_serial();
void loop()
 update_serial();
 void update_serial()
    if (mySerial.available()) {
       msg = mySerial.readStringUntil('\n');
      Serial.println(msg);
and this is an output
OK
AT+CGATT=1
OK
AT+CGACT?
+CGACT: 1,1
+CGACT: 8,1
OK
AT+CGDCONT=1,"IP","jionet"
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","http://api.timezonedb.com/v2.1/get-time-zone?key=KXXXXXXXXX&format=json&by=zone&zone=Asia/Kolkata"
OK
AT+HTTPACTION=0
OK
+HTTPACTION: 0,200,385
AT+HTTPREAD?
+HTTPREAD: LEN,385
OK
AT+HTTPTERM
OK
when I add the line to add the response or data
C:
#endif
String msg="";
void setup()
  delay(500);
 #endif
  update_serial();
  update_serial();
  update_serial();
  update_serial();
  update_serial();
  update_serial();
 mySerial.println("AT+HTTPPARA=\"URL\",\"http://api.timezonedb.com/v2.1/get-time-zone?key=KXXXXXXXXXX&format=json&by=zone&zone=Asia/Kolkata\"");
delay(500);
  update_serial();
  update_serial();
  mySerial.println("AT+HTTPREAD=0,385");delay(2000);
  update_serial();
  update_serial();
void loop()
 update_serial();
this is the ouput
AT+CICCID
+ICCID: 89918680400450857327
OK
AT+CREG?
+CREG: 0,6
OK
AT+CGATT=1
OK
AT+CGACT?
+CGACT: 1,1
+CGACT: 8,1
OK
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","http://api.timezonedb.com/v2.1/get-time-zone?key=KXXXXXXXXXXX&format=json&by=zone&zone=Asia/Kolkata"
please help me to read the payload from the server
in "update_serial"
You only read until "\n".
What if there is additional text?
My ideas:
* Why (all at once) not read the whole content of the UART buffer?
* or (line-by-line) why not use a "WHILE" loop to read all available lines (multiple " \n")?
Klaus
in "update_serial"
My ideas:
Klaus
this is the ouput after whole data read upto my serial is available
AT+CICCID
OK
AT+CREG?
+CREG: 0,6
OK
AT+CGATT=1
OK
AT+CGACT?
+CGACT: 1,1
+CGACT: 8,1
OK
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","http://api.timezonedb.com/v2.1/get-time-zone?key=KXXXXXXXXXX&format=json&by=zone&zone=Asia/Kolkata"
OK
AT+HTTPACTION=0
now I get the response
thank you for responses
can you please tell me how to get the time from NTP server with GSM module
i read the AT commands from manual and try to do it but can't set the time.
Test Command
AT+CNTP=? response +CNTP:255,(-96~96)
OK
Read Command
AT+CNTP? Response +CNTP:,
OK
Write Command
AT+CNTP=””[,] Response OK or ERROR
Execution Command
AT+CNTP Response +CNTP:,
OK or ERROR
i tried with many server but can't get the time
Test Command
OK
Read Command
OK
Write Command
Execution Command
OK or ERROR
now i get the time from ntp there is a buffer overflow issue
impossible for us to see ... with the snippet of post#6
Additionally: On buffer overflow you usually get incomplete messages. You gave no information how your modem response looked like.
If you want fast and good feedback .. next time better post complete code and complete error description.
It saves yourself from a week long delay.
Klaus
LaTeX Commands Quick-Menu:
