Fluid guard ring is type of pcell, while MPP is a path (might be composed from a few layers defined in proper template).
So, difference is noticeable.
You can learn more about them from virtuoso layout suite documentation. For fluid GR should be at least separate manual called Virtuoso Fluid Guard Ring User Guide.
