HCRain
Newbie
Recently I'm searching for the parasitic diode breakdown voltage (BV) for LV MOS of BCD process (many of the values are found in spectre file of PDK).
However, the BV voltage mentioned in the name of iso ring is different fron that of the corresponding parasitic diode.
Take TSMC 180nm BCD as the example: for iso ring "shpdpwnblhvnw8_iso", its two parasitic diodes “shpdpwnblhvnw_dio_iso” and "hvnwnblpsubshp_dio_8_iso" are both with bv_max>20V, which is pretty higher than 8V.
Could anyone provide the possible reason? Thanks a lot.
