[SOLVED] MPLAB 16F677.INC file equivalent
JohnJohn20
Hi.
I am writing an .asm project using MPLAB for the PIC16F677 microprocessor chip.
However, MPLAB has no P16F677.inc or a f677temp.asm file (which I believe are required to write a .asm program for this chip).
Can anyone suggest an equivalent or a work around?
Thanks.
Not required, you can create your own if necesary but certainly useful if someone has already done it for you!.
I checked my copy of MPLAB and MPLABX and they both have the files you need included in them. I've copied them here for you anyway. These are the ones from the final release of MPLAB.
Brian.
  • 677_Files.zip
Thanks Brian. I have version 8.8 which actually doesn't seem to have files for many of the chips even though the project wizard lists the chip. Will update.
