Rizwan96101
Newbie
I have to interface 16 by 2 lcd with DSPIC30f2010 microcontroller via CD4015 shift register using only 4 wires (RS,EN,Data, CLK). I have done it in proteus using arduino but the same logic is not working on DSPIC30f2010.
I am very sorry that I have posted for the first time here and after sending my message i lost this thread.I was finding it to add details. I just caught it through my email. The Arduino code on the LCD attached with the lcd of the inverter board (purchased from Market) is working fine on the LCD as well as the in the proteus simulation (right picture). The code written for the arduino is given below,This is a very badly worded question. Also I don't see how the photo relates to the schematic.
You say the code works with the Arduino - you will need to show us that code so we know what you are aiming at.
You say that it doesn't work with a dsPIC30F2010 but you don't say in what way it is not working. What is it supposed to do? Show us the code you are using (there a numerous things that can stop these very old processors from working if you don't set them up correctly.
Susan
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 #define LCD_RS 8 #define LCD_E 9 #define Data_Pin 4 #define Clk_Pin 5 //#define D6 6 //#define D7 7 void lcdwrite(int select, char data) { digitalWrite(Clk_Pin,LOW); digitalWrite(LCD_RS, select); //Change RS for command/data char LcdDataBus = (data >>4 ); //Send higher nibble char Maask = 8, Flaag=0; for (int t=0; t<7; t++) { Flaag = LcdDataBus & Maask; if(Flaag==0) digitalWrite(Data_Pin, LOW); else digitalWrite(Data_Pin, HIGH); digitalWrite(Clk_Pin, HIGH); delayMicroseconds(100); digitalWrite(Clk_Pin,LOW); Maask = Maask >> 1; } digitalWrite(LCD_E, HIGH); delay(2); digitalWrite(LCD_E, LOW); delay(2); LcdDataBus = (data & 0x0f ); //Lower nibble Maask = 8, Flaag=0; for (int t=0; t<7; t++) { Flaag = LcdDataBus & Maask; if(Flaag==0) digitalWrite(Data_Pin, LOW); else digitalWrite(Data_Pin, HIGH); digitalWrite(Clk_Pin, HIGH); delayMicroseconds(100); digitalWrite(Clk_Pin,LOW); Maask = Maask >> 1; } digitalWrite(LCD_E, HIGH); delay(2); digitalWrite(LCD_E, LOW); delay(2); } void lcd_cmd(char cmd) { lcdwrite(0, cmd); } void lcd_data(char dat) { lcdwrite(1, dat); } void lcd_ini() { //Lcd_CmdWrite(0x02); // Initialize Lcd in 4-bit mode // Lcd_CmdWrite(0x28); // enable 5x7 mode for chars //Lcd_CmdWrite(0x0E); // Display OFF, Cursor ON //Lcd_CmdWrite(0x01); // Clear Display //Lcd_CmdWrite(0x80); lcdwrite(0, 0x02);//lcdwrite(0, 0x33); delay(15); lcdwrite(0, 0x28);//lcdwrite(0, 0x32); delay(15); lcdwrite(0, 0x0E);//lcdwrite(0, 0x28); delay(15); lcdwrite(0, 0x01); delay(15); //lcdwrite(0, 0x0C); //delay(15); //lcdwrite(0, 0x06); delay(15); lcdwrite(0, 0x80); delay(15); } void setup() { // put your setup code here, to run once: pinMode(4,OUTPUT); pinMode(5,OUTPUT); pinMode(6,OUTPUT); pinMode(7,OUTPUT); pinMode(8,OUTPUT); pinMode(9,OUTPUT); delay(150); lcd_ini(); lcd_data('h'); lcd_data('e'); lcd_data('y'); //lcd_data(0x61); //lcdwrite(1, 0x08); } void loop() { // put your main code here, to run repeatedly: } The same logic functions for the DSPIC are given below, void Lcd_CmdWrite(char cmd) { LCD_RS = 0; // Send LOW pulse on RS pin for selecting Command register char LcdDataBus = (cmd >>4); //Send higher nibble char Maask = 8, Flaag=0; for (int t=0; t<7; t++) { Flaag = LcdDataBus & Maask; if(Flaag==0) Data_Pin = 0; else Data_Pin = 1; Clk_Pin = 1; __delay32(5500); Clk_Pin = 0; Maask = Maask >> 1; } //LCD_RW = 0; // Send LOW pulse on RW pin for Write operation LCD_E = 1; // Generate a High-to-low pulse on EN pin delay_ms(5); LCD_E = 0; delay_ms(5); LcdDataBus = (cmd & 0x0f); //Send Lower nibble LCD_RS = 0; // Send LOW pulse on RS pin for selecting Command register //LCD_RW = 0; // Send LOW pulse on RW pin for Write operation Maask = 8; Flaag=0; for (int t=0; t<7; t++) { Flaag = LcdDataBus & Maask; if(Flaag==0) Data_Pin = 0; else Data_Pin = 1; Clk_Pin = 1; __delay32(5500); Clk_Pin = 0; Maask = Maask >> 1; } LCD_E = 1; // Generate a High-to-low pulse on EN pin delay_ms(5); LCD_E = 0; delay_ms(5); } void Lcd_DataWrite(char dat) { char LcdDataBus = (dat >> 4); //Send higher nibble LCD_RS = 1; // Send HIGH pulse on RS pin for selecting data register //LCD_RW = 0; // Send LOW pulse on RW pin for Write operation char Maask = 8, Flaag=0; for (int t=0; t<7; t++) { Flaag = LcdDataBus & Maask; if(Flaag==0) Data_Pin = 0; else Data_Pin = 1; Clk_Pin = 1; __delay32(5500); Clk_Pin = 0; Maask = Maask >> 1; } LCD_E = 1; // Generate a High-to-low pulse on EN pin delay_ms(5); LCD_E = 0; delay_ms(5); LcdDataBus = (dat & 0x0f); //Send Lower nibble LCD_RS = 1; // Send HIGH pulse on RS pin for selecting data register //LCD_RW = 0; // Send LOW pulse on RW pin for Write operation Maask = 8; Flaag=0; for (int t=0; t<7; t++) { Flaag = LcdDataBus & Maask; if(Flaag==0) Data_Pin = 0; else Data_Pin = 1; Clk_Pin = 1; __delay32(5500); Clk_Pin = 0; Maask = Maask >> 1; } LCD_E = 1; // Generate a High-to-low pulse on EN pin delay_ms(5); LCD_E = 0; delay_ms(5); }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 #define Blink1 LATDbits.LATD0 #define Blink2 LATDbits.LATD1 #define LCD_E LATFbits.LATF2 #define LCD_RS LATFbits.LATF3 #define Data_Pin LATEbits.LATE4 #define Clk_Pin LATEbits.LATE5 main() { Lcd_CmdWrite(0x02); // Initialize Lcd in 4-bit mode delay_ms(5); Lcd_CmdWrite(0x28); // enable 5x7 mode for chars delay_ms(5); Lcd_CmdWrite(0x0E); // Display OFF, Cursor ON delay_ms(5); Lcd_CmdWrite(0x01); // Clear Display delay_ms(5); Lcd_CmdWrite(0x80); // Move the cursor to beginning of first line delay_ms(5); Lcd_DataWrite('H'); Lcd_DataWrite('e'); Lcd_DataWrite('l'); Lcd_DataWrite('l'); Lcd_DataWrite('o'); Lcd_DataWrite(' '); while(1) { Blink1 =0; Blink2 =1; delay_ms(1000); Blink1 =1; Blink2 =0; delay_ms(1000); } }
this defines the delay after the rising edge. But I miss the delay at the falling edge.Clk_Pin = 1;
__delay32(5500);
