Memory utilization Option in MPLAB
Hayee
Member level 2
Hi all
I am using MPLAB XC8 compiler ver 6.15.
I am using PIC18f452 microcontroller.
My question is, is there any option from where I can see the detailed usage of my memory (i-e functions, variable assigned)? My memory is filling as I am adding code and lot of things to add on. so I want to see which function is utilizing more memory so that I can write a different optimize code for it
Thanks.
Hi.
There are several types of memory. Which one are you referring to?
There may be compiler console output as well as compiler report files.
Also the HEX file should give the flash size.
Klaus
LaTeX Commands Quick-Menu:
