[MOVED] CMOS VLSI Design. Threshold of CMOS regarding.
Prashanth.vinnakota
India
Is there any dependence of Vth (CMOS inverter) on Temperature in 180nm technology?
If so wat relation can be given between µn and µp?
Re: CMOS VLSI Design. Threshold of CMOS regarding.
The threshold of CMOS inverter is dependent on mobilities of electrons and holes.
In that aspect it is clear there is a dependence on temperature because the carrier mobility is dependent on temperature.
So what i ask is how that dependence is in 180nm standard technology?
Below pls. find the theory (Allen/Holberg).
For this process size I found TC(Vth) between -1.0 and -1.6 mV/°C :
  • Temperature_dependence_p95.pdf
  • Medium_Temperature-Coefficient_of_MOS_Vt_1,0.pdf
  • Medium_Temperature-Coefficient_of_MOS_Vt_1,3.pdf
  • Medium_Temperature-Coefficient_of_MOS_Vt_1,6.pdf
Sir,
It must be true because i found the threshold of each Inverter deviating slightly from mathematically calculated threshold when i went for designing in Cadence Virtuoso.
Thank you sir.
