yuvalkesi
Member level 5
I'm running VSIM.exe in a tcl from a software, and output the result to a log file. All works well, except in case there's a compilation error (even simple syntax error in the vhd file), I get this message in the log file:
and the vsim.exe is still running in the background forever. If I kill it thru the task manager the log file will show:
How can I know the VSIM failed and why isn't the process terminated by its own?
My tcl I'm running is:
It seems as if the
is not working! otherwise I would not see the
Please help!
Thank you.
# Error in macro c:\My_Designs\msim.tcl line 7
# C:/Modeltech_pe_edu_10.2b/win32pe_edu/vcom failed.
# while executing
# "vcom file.vhd"
ModelSim>
# Error in macro E:\My_Designs\FPGA\Design\VHDL\ver_EB8C\vhdl\script_msim.tcl line 7
# while executing
# "vcom file.vhd"
ModelSim>
** Fatal: vish lost connection to vsim process.
cd c:\My_Designs\vhdl
set WRK work
if {[file exists $WRK]} {
} else {
vlib work
vmap work work}
vcom file.vhd
quit -f
It seems as if the
quit -f
ModelSim>
Please help!
Thank you.
