henry kissinger
Member level 2
The NMOS configuration is as below.
the gate voltage is 0 V
the source voltage is fixed to 0 V, the drain voltage is swept from -2 V to 2V.
We can see that the threshold of voltage difference between source and drain is very little, at drain voltage around -0.01 V.
What parameter of this NMOS shown in the second graph (Level1_Model) I can change in order to have the threshold voltage difference much negative, say -10 V ?
