ravipratap06
Newbie level 2
I'm working on the implementation of reed Solomon Encoder in VHDL. Can
you tell me how this block works?
The encoder is based on Galois field arithmetic where the 4 LUT blocks
are multiplied with 12,1,3,15.
We are giving input as 1 to 15(4 bit binary) to the multiplexer. The
control line is given as 1 at first. it is changed to 0 after all the
inputs have been provided.
So what will be the output after the control line is made zero in the
above block diagram?
