In your opinion does make sense to buy such board and use it without their compiler?
EasyPIC PRO v7 has mikroProg integrated onboard so you can use it with mikroProg suite which means that you can program it with any hex file.
So it should work with MPLAB. Hardware debugger will work only with mikroC , mikroPascal or mikroBasic compiler.
So at this point...an equivalent board you fill confident to suggest which works with MPLAB?
Yes I have been using Hitech, the free version. I am interested in ethernet communication.
