jessy_kjl
Newbie level 2
hi, i need help with my vhdl code:
entity DU is
Port ( gcd_inA, gcd_inB : in STD_LOGIC_VECTOR (3 downto 0);
selP0 : in STD_LOGIC;
selQ0 : in STD_LOGIC;
ldP : in STD_LOGIC;
ldQ : in STD_LOGIC;
ldG : in STD_LOGIC;
reset : in STD_LOGIC;
clrG : in STD_LOGIC;
opcode : in STD_LOGIC_VECTOR (1 downto 0);
clk : in STD_LOGIC;
gcd_out : out STD_LOGIC_VECTOR (3 downto 0);
Eq : out STD_LOGIC;
Lt : out STD_LOGIC;
data_outP, data_outQ, alu_out : buffer STD_LOGIC_VECTOR (3 downto 0));
end DU;
architecture Behavioral of DU is
begin
regP: process (ldP,selP0,clk,gcd_inA)
begin
if reset='1' then
data_outP <= "0000";
elsif clk'event and clk='1' then
if ldP ='1' then
if selP0 = '1' then
data_outP <= gcd_inA;
end if;
end if;
end if;
end process regP;
regQ: process (ldQ,selQ0,clk,gcd_inB)
begin
if reset='1' then
data_outQ <= "0000";
if ldQ='1' then
if selQ0 = '1' then
data_outQ <= gcd_inB;
end if;
end if;
end if;
end process regQ;
regG: process (ldG,clrG,clk)
begin
if clrG='1' then
gcd_out <= "0000";
if ldG='1' then
gcd_out <= data_outP;
end if;
end if;
end process regG;
ALU_module: process(data_outP,data_outQ,opcode)
begin
case opcode is
when "00" =>
alu_out <= data_outQ - data_outP;
when "01" =>
alu_out <= data_outQ - data_outQ;
when "10" =>
alu_out <= data_outP - data_outP;
when others =>
alu_out <= data_outP - data_outQ;
end case;
end process ALU_module;
--comparator;
Eq <= '1' when data_outP = data_outQ else '0' ;
Lt <= '1' when data_outP < data_outQ else '0' ;
end Behavioral;
in the rtl schematic, the buffers appear as output. why is this so?
thanks in advance!
entity DU is
ldP : in STD_LOGIC;
ldQ : in STD_LOGIC;
ldG : in STD_LOGIC;
clk : in STD_LOGIC;
Eq : out STD_LOGIC;
Lt : out STD_LOGIC;
end DU;
begin
begin
if reset='1' then
if ldP ='1' then
if selP0 = '1' then
end if;
end if;
end if;
end process regP;
begin
if reset='1' then
if ldQ='1' then
if selQ0 = '1' then
end if;
end if;
end if;
end process regQ;
begin
if clrG='1' then
gcd_out <= "0000";
if ldG='1' then
end if;
end if;
end process regG;
begin
case opcode is
when "00" =>
when "01" =>
when "10" =>
when others =>
end case;
--comparator;
end Behavioral;
thanks in advance!
