mt_maque
Newbie
Good afternoon to whomever this may concern. I am trying to create a calculator system, that will be programmed on the D10-LITE FPGA board. This is the system that I would like to implement
You are to implement a system that performs calculations on 4-bit numbers (your output must account for this). It is capable of performing add, subtract, and 2 other custom operations. The values are to be input from the switches as hex numbers. As the value is entered, it is to be shown on the 7-Segment Display in decimal. The functions to be performed are also input from the switches. After the user enters a value, presses a function, and then the second value, your system will display the result on the 7-Segment display.
