ywguo
Junior Member level 2
Re: Z state, Is it a software bug or a fault of the circuitr
Hello,
I simulated a gate-level netlist with SDF annotation from layout using LDV 3.4 for LINUX. It showed Z state from a few registers at the waveform, although the simulation proved that the circuitry worked fine. First I suspected it was a bug of the waveform display. Then I printed the register value using $diaplay. It was Z state, too. The Z state didn't propagate to the next register. For eg., in a shift register, the 26th register was Z, but the 27th register had never capture a Z state from the 26th register.
I am really confused. Any comments are welcome.
Thanks.
Yawei
Added after 37 minutes:
I found it is a fault by myself. After optimization of the PR tool, the netlist had changed a little. Some ports and signals changed, but the declaration for the original wires are still there and become hi Z when simulation.
Thanks
Yawei
Hello,
Thanks.
Yawei
Thanks
Yawei
