yagi antenna radiation pattern
max232
Member level 5
Member level 5
simulate antenna
with what, I must simulate an Yagi antenna and Design of a microstrip patch antenna
thaks
yagi cst
To desigh the patch antenna You can use 2.5D simulator (MWO, Sonnet), or CST-MWS if Your structure has many layers. To Yagi-Uda ... usually the formulas from Balanis book gives the good result, but if You want to simulate it, try to use SuperNEC or CST-MWS.
With responce,
Kit-the-great
umts supernec
winnec or supernec will be fine...
simulate antenna
doesn't ansoft have a package for antenna design?
Since MWO or Sonnet uses a close box for simulation (In sonnet only one wall canbe removed to obtain radiation pattern) they should not be used to simulate a patch antenn. Do it with free of cost using ensemble student version. Otherwise IE3D is a good and $ wasteing option.
Also for a Yagi CST should not be tryed. It will take very long time to optimize a yagi(Actually Uda was the inventor, poor man). SuperNEC is a good choice but many other NECs are available for free of cost.
:!: :idea: :?:
With responce,
Kit-the-great
simulate antenna
hi.
you can use "superNEC" or "HFSS" or "HPHFSS"
to simulate this antenna.
thank u.
simulate antenna
hi
please can you tell me the kind of smart antenna witch is used on BTS(base station)
thanks
Added after 19 minutes:
an other question please
wath is the caractériustics of smart antenna used in UMTS
LaTeX Commands Quick-Menu:
