abort
Newbie level 2
xilinx fft core spectrum
I have audio data coming out of an ADC.
I wanted to use a Xilinx FPGA to run it through a FFT and I noticed that Xilinx has a FFT ipcore available in their CORE Generator that I believe I can use. The input requires a real part and an imaginary part, but I only have the real part [the data coming off the ADC].
I read "Distributed Half Band Filter (DHBF) provides an efficient mechanism for converting a digitised signal from an ADC into a complex representation for input to the FFT transform." and "The ADC output is first applied to a DHBF (Distributed Halfband Filter), which converts the real input signal to a complex output at half the rate."
So my question is does Xilinx also provide a DHBF ipcore through CORE Generator or how would I otherwise go about getting a DHBF to put between the ADC and the FFT?
Thank you very much.
