I designed an analog switch. The switch is T type, which is composed by 2 T-gate and a NMOS.
The PMOS W/L is about 35000um/0.5um and the NMOS is 7000um/0.5um. That means the on resistor is very low, the test results is about 2.5ohm; but the paracitic capacitor is very large.
The BW simulaiton results of this analog switch is about 2G, but the test results is only 30MHz. It is a very big difference.
I thinks maybe 3 reasons reasons results in this differenc.
1, Model is not accurate.
2, layout parasitic devices.
3,Test equipment. (Other products can get 300M BW test results, so i think this is not main reason.)
I think ,the layout parasitic devices should decrease the BW , but should not effects so obviously. It differenc is about 70 times.
So, who can give me some suggestions about this issue. Thanks.
