writing efficient code PIC microcontrollers
gehan_s
Member level 3
Member level 3
Sri Lanka
Dear all,
Lately I have been working with some projects where timing is critical and hence have decided to learn how to write more efficient code.
Can you direct me some where or give some pointers regarding things like multiplication, division and ANY other ways of making my code run faster. I am using MikroC pr for PIC.
Best regards
various techniqes can be used, e.g. a few ideas
1. addition and subtraction take about the same time, multiplication longer and division many times longer - I have speeded up applications by sveral hundred times by changing algorithms to remove division
2. use 8 or 16 bit integer arithmetic rather than 32 or 64 bit if the application data allows
3. floating point arithmetic takes longer than integer in particular where the processor does not have a floating point coprocessor - again 32 bit floating point arithmetic is faster than 64 bit faster than 128 bit etc
4. use shift opertors << for integer multiply by 2 or >> for division by 2 (take care when using signed numbers in that the C standard does not specify if >> is logical or arithmetic shift)
5. using pointers rather than array indices to access arrays (although the code my be clearer to readers when indices are used)
6. look at loops - are there calculations which can be moved outside the loop (an optimising compler should find these for you)
you can write time critical parts of an application in assembly language (assuming one has the skill!)
assuming the technology supports it one can increase the clock speed, move a higher speed version of a processor, a more powerful family (one has to then port the application) or to processors with application specific hardware such as DSP processors or even to multiprocessors
compilers ofen have various levels of optimisation (for code size, speed, etc)
if using free versions of compilers often one has to purchase a license to obtain the best optimisation
