Phoenix1996
Newbie
Hello
I am designing an inverter for input ranging from 220-440v DC 13A, and output of 220v ac 50hz, it is designed for 5kw, using pic30f2010 as an oscillatory circuit.
Can any body tell me how to produce SPWM of 40khz using pic PWM pins 23-26, 1L,1H, 1L,1H to drive an IGBT H-bridge using Sin wave lookup table of 200+ values of steps per cycle.
I am using pi filter using 6mH choke and 10uf/440V foil capacitor.
I need to add feedback system that checks the output voltage and increases dutycycle of SPWM accordingly.
This is the first stage of the inverter, later on I want to ad LCD to show these values.
I want the inverter to switch off when the I put voltage is less than 220V DC from PV array.
Ps: do you think ACS712 module at the output to check the current sensing and give feedback and also check shortcut parameters.
I am planning to use Lm393 for this comparison.
Kindly guide me in this regard.
Thanks
Thanks
